Re Jet?
Ok I give up! Time to make her quiet again. There will be a sound check this month at what will be my 4th "Ozark Fall Color Tour". (I also belive this will be the last FCT).
I have the exaust of my 2001 S. end cap drilled out to 1 3/8", and both baffles "swiss cheesed". It would never make 96db. found a washer that was a perfect fit inside the end cap, drilled the center out to the 3/4" stock size and spot welded it in place.
Poof! Much quieter! Also got back some low end torque. Not a bad trade.
Now to my question. With my jetting at the burned recomended 142.5 main, 25 pilot, DJ needle at the 4th clip, fuel screw 2.5 turns out, (1000ft Alt.) Do I need to rejet? Is stopping up the end cap back to the stock dia. of 3/4" warrent a rejet?
What do you think?
Thanx in advance for your sugestions.
Dan.
You would know better than any one. If anythig it will run rich. How does it run compard to before? I doubt it needs any rejet but you can probably go to a 140 main in any case.
