CRF Off idle stumble
i have an 06 crf250 and it has an off idle stumble.... any way to fix that??
different pilot or boysen quickshot???
first thing to do is confirm the pilot jet with the fuel screw.
with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go slowly back out till the idle smooths/peaks.
this should happen between .5 and 2.5 turns.
less than .5 you need a smaller pilot jet.more than 2.5 turns you need a bigger pilot jet.
once you have the pilot circuit tuned you can start adressing the other circuits.
yeah wel the pilot didnt work so i ordered a boyesen quickshot should do the trick itll be here tomorro
ill let you know how it works
