Pro Circuit 496
Hi,
I tried to look for some info on the Pro Circuit 496 muffler - couldn't find too much here, other than that it is a quiet pipe.
Basically my questions are:
1) How it will perform with a original "E" header pipe (I have a "S" with "E" exhaust system) ? - Can I expect a power boost with it compared to the "E" system?
2) If a header is needed, which one can I use ?
Thanks.
it will perform like other slip on.loses some weight,makes extra noise.the motor will rev a little more freely.
you can use pro circuits head pipe,any of the fmf head pipes or the E head pipe.
Should I expect the performance of a full system (like Yosh or muzzy) by adding an after-market header (FMF Powerbomb or Pro Circuit) ?
no,any othe systems that can be either a slip on or full system will be limited by the head pipe diameter.
the systems that make the gains have a much bigger head pipe and cannot be used as either slip or full.
