Valve swap
I have a 02 cr250r that i had the suspension re-valved by pro circuit. would i be able to swap the valves from that suspension over to my 06 crf450 suspension? that way i don't have to cough up the big bucks for another PC re-valve job!
Your '06 450 is completely different. Although PC only does a shim shuffle and does not change the actual piston, the piston size went from 23mm in '02 to 33mm in the '03 and newer models.
Take Care, John
