passatv6 Posted October 11, 2005 Whew, I started at 4 pm and ended at 11:30 last night, but I got all the parts back on, I did not realize how in depth that install was. I got to take a short spin, and WOW what a difference, I went with 155 and 25. My question is I think when I took off my throttle cable I might have messed with the screws when I took it off, and now my throttle does not snap back, it there something to check the correct throttle placement. thank you 🤣 Share this post Link to post Share on other sites
palys2 Posted October 11, 2005 The return cable should be adjusted so that there is about 1/8" of thread showing above the top of the upper adjustment nut. The pulling cable should be adjusted so that there is about 1/8" of play in the throttle tube. Share this post Link to post Share on other sites
mickeydee Posted October 11, 2005 i would check to see if anything was rubbing or interfearing with the cable or throttle wheel.mine is spring loaded and the wheel will snap back if i turn it by hand Share this post Link to post Share on other sites
drzrobbcanuck Posted October 11, 2005 if you had the grip loose on the handle bar, check to see that it's not pushed on too far. Share this post Link to post Share on other sites
kgeakin Posted October 11, 2005 Check the angles of the metal sections of the cables that fasten to the bracket on the carb. I just worked on mine and had the same problem. Changed the positions and the binding went away. Kind of obvious if the angles are causing the binding if you take a good look at them. Share this post Link to post Share on other sites
passatv6 Posted October 12, 2005 thanks everyone, I will definatley mess with is tomorrow and let you know if it is OK. Share this post Link to post Share on other sites
