schuon Posted October 11, 2005 Does the Enduro Engineering Speedo drive eliminator just eliminate the cable coming out of the black piece on the hub or does it eliminate the black thing and act as a spacer between the hub and the fork? Thanks, Here's the link. http://cgi.ebay.com/ebaymotors/Enduro-Engineering-Speedo-Drive-Eliminator-17MM-xr-ktm_W0QQcmdZViewItemQQcategoryZ34284QQitemZ4574509570QQrdZ1QQsspagenameZWD1V Share this post Link to post Share on other sites
Red_Snapper Posted October 11, 2005 It eliminates the oem odo housing and is a spacer. Don't forget to take out the odo drive ring (with tabs) from underneath the seal. You'll need to pull the seal to do this. It can be pried out gently and reinstalled. Share this post Link to post Share on other sites
erussell Posted October 15, 2005 I never needed to remoce the ring with the tabs. There is a groove in the EE part that allows the ring and tabs to remain. This is a top shelf quality part IMHO. Share this post Link to post Share on other sites
