Hows this?
I have a 2005CRF250X with the baffle removed and open air box and am wandering if i need to change anything. I havent riden it since that but not in gear it doesnt seem to bog.
This is what i eventually want:
Procircuit T-4 muffler
FMF powerbomb header
twin air powerflow kit
JD jetting
power now
boysen quickshot
open air box
and am wandering if i left out anything.
The JD kit has everything you need jetting wise to to keep your bike carbuerating nicely as you add mods. Most importantly it has detailed instructions on what included parts you should use with your personal set of mods. Cheaper route #42 pilot,drop clip one slot and #155ish main (assuming you cut the airbox).
Scotty
I rode it 2day and it seems that it is bogging from 1/2throttle to full throttle. What should i change? main, needle?
Thanks,
Kyle
Temp,alt, humidity, mods etc.?
Here's what I run in Wa.:
Jd kit
winter cold weather needle 162 main
summer warm weather needle 160 main
Make it easy on yourself and get the jd kit. It has everything you need and just as importantly it has instructions. Also get an aftermartket fuel screw (zipty or scotts) for fine tuning on the trail.
