AtlantaRider Posted October 12, 2005 Hey Guys, New here so forgive me if this has been asked before. I've got a new CRF80f for my son and a CRF230f for me. Pulling out the baffles sounds like a great idea - gotta love the sound, but didn't know if this would cause other problems. These bikes are made pretty specific these days and I don't want to end up with burnt valves or something. Am I cool to remove? Share this post Link to post Share on other sites
tcskibike Posted October 12, 2005 Im no expert but I wouldnt worry to much about it. It will be louder and you may need to rejet but generally your bike will run better. Share this post Link to post Share on other sites
xXHondaOwnsXx Posted October 12, 2005 It will be perfectly fine, nothing will go wrong. Might want to pull the snorkels too and re jet. I'd suggest 120 main 45 pilot needle in 4th position for the 230. Ask in the CRF80 forum what to re jet it to. Share this post Link to post Share on other sites
toneconsultant Posted October 12, 2005 I'm sure you could be fine since I'm assuming you're just cruising around with your son. The problem that could happen would be you could seize your bike. Honda knew this so they offer a "Power-up kit." It's a rejetting package for your bike. You should get it anyway because your bike was sold "under jetted." Anyway, that's the only issue you will run into. Share this post Link to post Share on other sites
4strokeridertt My Rides (3) Posted October 12, 2005 If your above about 500 feet you should be fine, down at sea level your bike will run even leaner than it already does. Good to rejet. Share this post Link to post Share on other sites
2005CRF150f Posted October 12, 2005 i guess i should re jet because i'm right at sea level Share this post Link to post Share on other sites
wolfgang123 Posted October 13, 2005 what is a baffle and would it hurt your bike if you did not re-jet Share this post Link to post Share on other sites
PGer555 Posted October 13, 2005 what is a baffle and would it hurt your bike if you did not re-jet WOW!!! Share this post Link to post Share on other sites
boi_racer01 Posted October 13, 2005 the baffle is the piece inside the spark arrestor in your exhaust that helps to keep the noise down. when you take it out it makes the bike louder. you may have to rejet. Share this post Link to post Share on other sites
wisenhimer301 Posted October 13, 2005 Hey AtlantaRider......you sound just like me. I also bought myself a 230 and my son an 80. We now spend more time together and have ALOT of GREAT times. To answer your question.....I have pulled the baffle out of my 230 and have had no problems. The bike is set up to run lean so, don't fool with the airbox until you re jet the carb! If you do, you're asking for trouble. I've done some research on both bikes. Drop a message in my inbox if you would like some help. Share this post Link to post Share on other sites
AtlantaRider Posted October 13, 2005 Thanks for the responses guys. This site is great. One more queston for ya....I heard mention of the power up kit?? What's involved in this kit and where can I get one. Again, sorry for being lazy and not doing a search. Try not to flame me too badly and if I'm unworthy of a response, I understand....I'll start searching The path of least resistance is the man way! Share this post Link to post Share on other sites
AtlantaRider Posted October 13, 2005 Don't respond to that last email....I'm an idiot. Any chucker could see the sticky pinned at the top of the page for rejetting. Great information there BTW. Does the power up kit seem to make a big difference for those of you that have done it?? Share this post Link to post Share on other sites
xXHondaOwnsXx Posted October 13, 2005 Yes it does make a difference. Use a 120main, 45 pilot and the stock needle in the 4th position. Share this post Link to post Share on other sites
Alaskan_h230_gurl Posted October 13, 2005 http://www.off-road.com/dirtbike/projects/crf230f/1/ Take a look at this, I found it very helpful. You will too!! Congrat's on the new bikes! Share this post Link to post Share on other sites
wolfgang123 Posted October 14, 2005 thanks alot you guys. but mister pger555 this is my first bike and i am only 13 you insted of laughing at me just help. Share this post Link to post Share on other sites
wolfgang123 Posted October 14, 2005 i removed the baffle. i dont whant to rejet what will happen if i dont Share this post Link to post Share on other sites
PGer555 Posted October 15, 2005 Sorry but a baffle is kind of common sense. Anyway if you dont rejet over time your engine will suffer, plus ull get more useable power if you upgrade the air filter and rejet properly. Share this post Link to post Share on other sites
wolfgang123 Posted October 15, 2005 can any one name some good up-grades for a 150 honda and a place to get an after maket air filter Share this post Link to post Share on other sites
redrider150f Posted October 15, 2005 WOW!!! you didnt know what it was at some point in your life either, believe me your no expert on motorcycles Share this post Link to post Share on other sites
PGer555 Posted October 15, 2005 F*** you dude, i never said i was an "expert" on motorcycles. No offense to wolfgang but if you didnt know that a baffle is a device to control the flow of sound or energy then you need to enlighten your vocabulary. Share this post Link to post Share on other sites
