What brakes to use on a YZ426 02 ??
Hello all,
I am looking into upgrading my stock front brakes to something that can actually make the bike do a stoppie. I am going to be kitting my bike up to enter into a couple of local Supermoto's. Just maily to have fun...
Can anyone suggest a good kit to use on the front brake system that will hold up to competition? I would like to go with a 320mmm Floating disc as well as changing the calliper and master cylinder. What are you guys using?
Any info is much appreciated !! :banghead:
Daz
The most popular setup around here is the Motomaster Caliper and Rotor. The MM caliper will work well with the stock master cylinder and you might not even need a radial master cylinder. I ran with this setup last year without trouble and added the 13mm Magura this year. I like the Magura but it's not a must have.
I have an '01 426, with a Motomaster caliper, Brembo 320mm floating rotor, Honda style brake line routing, and the stock master cylinder, this set-up works well. :banghead:
