E pecock conversion
i was just wondering ifthe E fuel pecock will bolt on to the S fuel tank?
YES it will.
Ahhh. And eliminates the vacuum-type operation?
I noticed Pingel makes a fuel valve for the DR also.
I have always wondered if the pingel is worth the $$$$
Yes it will....BUUUUT, you won't be able to switch the petcock to reserve because the handle bumps into the metal flange of the steel tank.
The S petcock has a spacer in between the actual petcock and the steel tank so you don't have this issue. You'll need to make that spacer work with the E petcock.
