Will the 450X shock spring work on the 250X?
I was wondering if anyone knew if the 450X shock spring would work on the 250X????
I believe I need a heavier spring (180 lbs)for my 250X and I think the 450X is a 5.5 spring and the 250X is a 4.8 spring. My riding buddy has a 450 and has his stock spring that I can use.
Any ideas? Is this too much spring for my weight?
I ride East Coast HS.
Yes, the fofiddyX spring will work and at 180lbs. it's a good spring for your weight. If you want to play with spring weight recommendations try: http://www.racetech.com/evalving/menu/searchdirt.asp
If you find out that you do need a new spring, let me know, we carry a full line of spring by eibach, racetech and factory connection.
It is best to buy the front ones also. Very inexpensive but needed if you change the rear.
