Motor Oil
Chevron supreme 10-40. No expensive witch oils for this bike. Its about a buck twenty a quart. Just tore it down for a valve issue and the piston/cylinder looks great, no bottom end or clutch issues at all. Oh ya, works on both sides of the motor too.
i think a CRF owner should run Energy Conserving oil in the motor side, since it does not touch the clutch. Don't put it in the clutch side because it can cause the clutch to slip. But, the molly is great for reducing friction and wear. Don't worry about excessive costs, as many readily available car motor oils are energy conserving.
