WildbillinNJ Posted October 16, 2005 Has anyone else run into this? I am told that to replace it I do not need to split the cases but that I have to only open up the clutch side of the bike and disconnect everything and it will slide out. Best place to buy parts? Is the manual available on here in PDF format? Any and all help would be greatly appreciated. Thanks in advance, Bill Share this post Link to post Share on other sites
97chevy Posted October 16, 2005 Here is a link to a 03 Yzf owners manual. http://www.thumperfaq.com/oemmanuals.htm The best place to buy pars it probably the TT store. They have great prices. Share this post Link to post Share on other sites
WildbillinNJ Posted October 16, 2005 Thanks Chevy. Looks like it is not too bad of a deal to replace but I will see once I get it open. I may need to get the '02 manual, I don't know if the part numbers are the same or if the assembly/disassembly is the same between model years. Thanks again for the help. Share this post Link to post Share on other sites
Polar_Bus Posted October 16, 2005 Has anyone else run into this? I am told that to replace it I do not need to split the cases but that I have to only open up the clutch side of the bike and disconnect everything and it will slide out. Best place to buy parts? Is the manual available on here in PDF format? Any and all help would be greatly appreciated. Thanks in advance, Bill It's not a difficult job at all. You will need to pull the complete RH engine cover. Remove the shift lever, remove the RH cover, then pull the shaft assembly out from the right side. There is a seal behind the shift lever on the shaft, definately want to put a new one on. Good luck, Share this post Link to post Share on other sites
