Got the JD needles
Burned, here's what I have- new fcr carb, 3+3 airbox mod, FMF titiaum 4 full system exhaust, K&N filter, motor stock. The stock jetting is 160,38,60 just received the JD needles, blue and red.
Need your wisdom setting the carb up for 5200ft elevation.
Thanks :banghead:
im not srue.probably a provision for the crank case vent.plug it and run the vent hose to the atmosphere.
Still waiting for my E intake boot and the 39mm intake pipe. When I get it installed will let you know how it went, hopefully before the weather turns blah, boy you guys got hit by the white stuff a couple of weeks ago!!
