can an s model headlight be converted
i was wondering if i can use an s model headlight on an e model with the stock e model plastic?
i got a universal handlebar switch but i want the high low beam to work...
i know the plug will have to be changed.
thanks
j.w
i put an e headlight on my s and it fit great the s headlite is really heavy. the plastics are different and the mounts are different. i wouldnt put the s one on it isnt very good anyway
S head light in the E plastic is not and easy thing. The S headlight mounts in a metal frame and the plastic is just a cover. The E plastic is the mount. The glass S headlight is too heavy for the E plastic.
If you are asking if the E shell with fit an S headlight assembly the answer is no, the lights are of different sizes with the S being much bigger.
thanks,
is there a light i can get for the e plastic, that will have the high low beam
bulb?
thanks
j.w
If you can't find a dual element bulb that will work for the E either modify the housing to accept a bulb that has high / low beams or buy something aftermarket.
I modified my Acerbis DHH headlight to accept H4 bulbs. Worked out well.
If you are interested in trading a yellow "E" headlight for my yellow "S" one, let me know.
