compression check
Does anyone know the thread of the spark plug hole in the head. So I can get the proper compression check fitting. Is it 14mm? Also I have never done a compression check so can someone give me instructions on how to do it.
I mostly do comp checks on 2-strokes, but should be same principle:
Screw your gauge into the plug hole. Open throttle fully. Crank motor until gauge stops increasing (usually takes several spins of the motor).
How would you get the exhaust valve to close on a 03 and newer model???
