jamieyz426f01   Posted October 17, 2005 my yzf426 was running reasonable(bogged on the bottom) because i put an aftermarket pipe on it. so i tried to correct the bog by moving the needle clip DOWN 1 notch, i also messed with the pilot screw and can't remember where it was before🤣🤣. it now only idles with the choke out and backfires real bad on deceleration. would appreciate your advice greatly Share this post Link to post Share on other sites
Wayward Son   Posted October 17, 2005 where is the fuel screw set now?set it at 2 turns out for a test. Share this post Link to post Share on other sites
jamieyz426f01 Â Â Posted October 17, 2005 where is the fuel screw set now?set it at 2 turns out for a test. oki doki, i think i have got it at about 1 3/4 (going from the manual, the manual is for the 2000 model though ) do you think it is anything to do with needle clip? Share this post Link to post Share on other sites
Wayward Son   Posted October 17, 2005 did you take the enitre slide out at any point? Share this post Link to post Share on other sites
jamieyz426f01 Â Â Posted October 17, 2005 did you take the enitre slide out at any point? yes, and from what i remember there was one wheel that kept falling off, the plate that is on the slide fell off so i cleaned it up and put it back how i thought it came out. thanks Share this post Link to post Share on other sites
Wayward Son   Posted October 17, 2005 are you sure you got the vacuum release plate back in correct?sounds like you didnt. http://www.pbase.com/image/25566126/medium.jpg it goes opposite of how it looks like it should. Share this post Link to post Share on other sites
jamieyz426f01 Â Â Posted October 17, 2005 are you sure you got the vacuum release plate back in correct?sounds like you didnt. http://www.pbase.com/image/25566126/medium.jpg it goes opposite of how it looks like it should. ill go check thanks for all the help Share this post Link to post Share on other sites
jamieyz426f01 Â Â Posted October 17, 2005 i think i had it the wrong way it was a "W"(meant to be M) and the hole was at the top. Share this post Link to post Share on other sites
Wayward Son   Posted October 17, 2005 yes,thats what your problem is. Share this post Link to post Share on other sites
jamieyz426f01   Posted October 17, 2005 yes,thats what your problem is. ahhhh your the greatest 🤣 its all back together now. thank you sooo much i will report back with a test ride tomorrow 🤣 Share this post Link to post Share on other sites
jamieyz426f01 Â Â Posted October 18, 2005 bike runs awsome now way better throttle response, easier to ride and for some reason i have much more confidence in corners . all in all i think a successful operation Share this post Link to post Share on other sites
