Idling Problem
My bike stays around 4300 RPMs after I hit the throttle and wont return to normal idle. I tried adjusting the idle but no matter where I set it after I hit the throttle it stays above 4000 and only sometimes does it return to normal idle after 30 seconds or so. Thanks for any help.
Try cleaning the carb, lubing the cables, and putting a little bit of grease in the throttle tube. and make sure your jetting is right
first try playing with the air mixture screw, that is more than likely the problem.
oh yeah, if that doesnt work. try the valves, just check the clearance. these kxfs are more than notorious for the valves wearing out.
If it was the valve clearances then it probably would not want to idle at all.
The carb is clean and the cables are lubed adjusted and working fine and the valves are in spec. The jetting is good also. It has done it since it was new it will idle fine after start up until I hit the throttle. After that it idles at 4000-4300.
