Will R Plastics And Tank Fit The X ?
does anybody know if the r plastics and tank will fit the x??? or what do i have to do to make it work... i want a smaller tank, and i want to ditch all the lights and stuff i dont use, thanks
you shouldn't have a problem putting an R tank on an X. The front plate will require some mods to the stock upper clamp or buying an R upper clamp, some people around here have done the mods before. The rear fender and left side plate aren't interchangeable.
i have an x and i have 250r black plates all around on it. i had to cut alot of plastic off the plates but i made it fit and it looks like they are made for the bike. for the rear fender you will have some wire harnesses that will have to be moved to the side and kinda stashed away elswhere where they used to be attatched to the fender itself. but you can make it work and it looks sweet. i would recomend black!!!
