Water Pump Impeller 2005 CRF250R
im helping a friend out with his bike and i took off the water pump cover but i cant figure out how to take off the impeller? anybody know?
i get that but the bolt thats a 10mm is a solid mount to the impeller to when i turn it to the left it just turns with it. i cant really jam anything in there to stop it from turning cause its a solid mount you know what i mean? if you could take a picture of it that could help but i doesnt say anywhere in the service manual of how to do it. like a front sproket you can jam a wrench in there and it wont move so you can remove the bolt but there is no bolt its all one piece with the impeller. any advice will help
Put it in gear, lock up the rear brake and give the ratchet/socket a quick hit.
i had the experience with my 04 crf 250 and i do not believe the impeller thread has changed from 04-05. you will need an impact wrench. MAKE SURE it is set the right way or YOU WILL toast the old impeller. i did it and its not an easy ordeal. if you do it right the thing will just zip right off the shaft. good luck
