Xr 200 Exhaust Making Funny Noise?
My Wife has a 2000 xr200 which keeps making a funny chirping or squeal when you hit the throttle hard, the noise seems to be coming from the exhaust. What is it and how do I rid hear bike of this funny squeal, the bike runs good but makes that funny noise?
is there any little leaks around the baffle/tip?.. mine had the same thing, but i had cut off the baffel on the inside and that solved it for me but i dont know if you want to cut off your baffel
dont keep the baffel out, if yoiu ghave to cut it and leave the tip, otherwise you will loose all backpreasure and it will kill your engine's top end
top end as in valves, piston, cylinder, rings.. all wear out without backpreassure
it will improove power, for a little while
I only removed the baffle to identify the noise. It stays on, and we put up with the chirping sound...
