Burned, DRZ400E(K4) Re Jet??
Burned, I was wondering if you can help me?
I have just fitted a DEP (www.deppipes.com) rear silencer(inc link pipe) to my DRZ400E(K4). The head pipe is std, std E air box, so i'm wondering what to re jet to?
It seems to surge at the moment when riding along at a steady pace and wont always tickover to well (dies every now and then).
The bike has now only covered say 15 miles so its brand new.
Any help greatly appreciated. :banghead:
Cheers
Darren :banghead:
try opening the fuel screw to 2.5 turns and confirm the needle clip is in the 5th spot.
the standard 165 main jet is fine if not to rich.
I'll give it a go.
Is there a mod on the E air box as well that can be done??
Is that 2.5 turns out from fully in??
Cheers
Darren :banghead:
Burned,What will the settings be if I was to remove the coast enrichner valve?
Sorry to go on what is the snorkle removal you can do in the air box?
Cheers
Darren
O.K Burned, So lets get this 100% clear in a comp jetting novice's head:
DRZ400E(K4).
DEP Silencer inc link pipe.
Std E air Box.
Std Eng.
So I take off the coast enrichner; I put in a 38 pilot jet and 75 pilot air jet; I open the fuel screw to 2.5 turns from fully seated and confirm the needle clip is in the 5th spot; You say the standard 165 main jet is fine (if not to rich) What would you suggest if it were to rich?
If you can confirm this :banghead: then I can go buy my jets and have ago this weekend. 🤣
Cheers for all the advice.
Darren :banghead:
you will end with the fuel screw between 1.5 and 2 turns with that set up.
160-162 main jet would be closer.
