Best way to bleed the rear Nissin brake
I need to bleed my rear brake and can figure out how to open the master cylinder to refill it or even just to let the fluid out...
Is there an FAQ out there? The technical article about brake bleeding is not brand specific.
I did the front fine, used a vacuum pump and it worked perfectly wow I don't regret spending a few bucks on that tool.
Thanks for your help!
I used a bottle of brake fluid with a piece of pipe running from the bleed nipple into the bottle. Push on your rear brake a couple of times and open the bleed valve (if that's the name), keep pressure on brake pedal and then close the valve again and repeat. Undo the 6mm bolt that holds the reservoir in place, this will make it easier to add brake fluid to it.
