New Speedo Cable
OK, the speedo cable on my '03 S broke so I ordered a new one from Ron Ayers. What I'm not sure about is; does the stock cable come off the worm gear that is at the bottom end of the assembly? The cable I got has a typical square end. I've tried to tug the old cable off the worm gear but it doesn't seem to want to let go :banghead:
The one end that goes into the gear assembly at the wheel is round and has a small rubber washer around it...There's a screw that holds that end of the cable in the worm gear so you need to loosen the screw on the gear assembly before pulling out that end of the bad cable...
Ahhh! A tiny set screw that I have yet to see because I have not degreased it enough to see. Thanks! :banghead:
