shooks Posted October 19, 2005 i need help! i have 05 drzsm. i just bought oem fcr39 and fmf power up kit.what is the best set up.im willing to do anything,coast enrichner removal,pilot air screw conversion.what jetting should i use. i have done 3x3,full fmf exhaust quite insert.i ride @sea level to 2000ft.also k&n filter.thank you Share this post Link to post Share on other sites
DRZDUal Posted October 19, 2005 What FMF power up kit? If its the SM model P.UP kit then thats for your stock Carb not the FCR Share this post Link to post Share on other sites
Wayward Son Posted October 19, 2005 the dj kit for the fcr carb doesnt work well.the needle has to much taper. go with 150-155 main jet 200 main air jet EMN needle 3rd clip 38 pilot jet 75 pilot air jet or 5/8 turn pilot air screw conversion 1.5 turns fuel screw. Share this post Link to post Share on other sites
shooks Posted October 19, 2005 thanx i will go with that set up.is that with or without coast enrichner. Share this post Link to post Share on other sites
MilleonAir Posted October 19, 2005 the dj kit for the fcr carb doesnt work well.the needle has to much taper. go with 150-155 main jet 200 main air jet EMN needle 3rd clip 38 pilot jet 75 pilot air jet or 5/8 turn pilot air screw conversion 1.5 turns fuel screw. How do you DO that!!!!????? 🤣🤣🤣 Share this post Link to post Share on other sites
Wayward Son Posted October 19, 2005 thanx i will go with that set up.is that with or without coast enrichner. with out. Share this post Link to post Share on other sites
shooks Posted October 23, 2005 burned spot on bike runs like its fuel injected. Share this post Link to post Share on other sites
driven Posted January 27, 2006 I've spent hours reading all the jetting posts and the one above is the only one close to my setup... I have an FCR coming for my '05SM as well. I am at 200'. I will be doing the 3x3 and either a Yosh SS or a Muzzy. Stock cams and base gasket. Would my jetting be the same as above? Is there some sort of kit that has an assortment of jets/needles or is it better to order everything separate? Where do you order from...sudco? What about a rebuild kit? Mine was used from an 00-02 KTM 520... Share this post Link to post Share on other sites
driven Posted January 27, 2006 Anyone? Burned? Burned? 👍 Share this post Link to post Share on other sites
