FUEL MIX screw: is this pic inverted?
That picture is of the bottom of the carb. But the carb is off the bike there for the photo. I think what you would see is, on the shifter side of bike look at the carb. Then look at the bottom of the carb and feel underneath, you should feel that big 17mm drainplug that is in your picture. Just to the left of that would be the spot for your fuel screw. Please note I have a WR250f but the carbs are very similar so they "should" be in the same place.
yer right jim. i finally got oriented, but its impossible to get to the screw, so have to take everything apart
z
