XR650r jetting question
2002 XR650r stock motor...pro circuit t-4 pipe...175 main..unknown pilot.
idles fine, easy to start...as long as the throttle is rolled on smooth, it runs perfect. but, hammer it quickly it hiccups.. i've searched for a list of carb-jetting-needle position specs, b ut can't seem to find em'. Any help would be appreciated. Thanks!
What position is the clip in the needle?I would try calling Dave Chase @ Pro Circuit.Get his two cents? I'm thinking needle postion(clip) and pilot jet since you "opened" it up with a pipe.What about at top end? See you in Baja!
Thank you "cosmo" I'm hoping to get all the specs, before taking the carb apart...so, I don't know which position the needle is in..i'm guessing it's a little off.
Maybe i'll just sell the silly Honda and buy a Husky...what do you think?
See you in Baja, for sure..."upstairs"
Ya know....I hope I DON'T see you "upstairs"! Yuk! I was also thinking you could have a low float bowl level? So that when you stab the throttle it's starving a little for fuel.What about thru whoops etc.? Any stumbling there? You might want to try this in the XR600/650 section?Check the international section also. See you in Baja.
Cosmo, I have received all the specs I need from the 650 forum.. You are a wonderful man. I will purchase for you- one- full frontal lap-type dance, from the transvestite of your choice. Peace out
  • Similar Content
    • By Rixter
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Doukis1
      New spark plug, new air filter. Went for a ride and all was good. Hadn't run it in a week and a half. Now it won't start. Getting spark. The plug is dry. Is it possible I over oiled the filter and it has somehow gummed up the carb/ float? Thanks
    • By mbennett95
      My 01' yz125 seems to be requiring a large amount of throttle to get off the line. I've ridden plenty of properly jetted 125's and none required quite so much throttle work from a dead stop. Even slipping the clutch it wont get going without a pretty healthy amount of throttle. Thinking it just needs a clutch rebuild kit and maybe a basket. Any info appreciated!
      If it helps any here is what it has done.
      FMF Fatty, VForce 3 reeds, and an iridium plug.
    • By Sam W.
      Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
    • By Ndh87
      I’ve got an old barn find ‘83 CR80R that needs either a new carb or a rebuild kit. I haven’t been able to find either anywhere.
      Does anyone know where I can find either?
      housing, bowl and all the hard parts seem fine, if I can find a rebuild kit with a new float I think I’ll be ok. Right now it runs but only when I leave the choke on, smokes heavily and likes to bog down on takeoff
