Pitster stroker 145 cc
just got her running ........using the stock bore this is a nice easy big cc mini motor we are prototyping for Pitster......with our g2 cam and a mild head this thing yanks away from a std. 125cc like it was standing still. Now we are @ 5 pm so i can dyno this beast GPX . dyno runs will be up tommorow.It sounds like our 160 cc KLX .....braaaap!!!!
Cant wait to see dyno! That sounds awesome!!!
You the man Dan, look forward to hearing the results. Call me 866-686-7869
we'll it's done....it gained 3hp and 3 ftlbs everywhere and it over revs better to 10800 than it ever did. i can't post the runs yet because my buner is down but maybe this weekend......std. hp was 8.0 @ 8000 rpm now we are 10.9 hp @ 8000rpm. and 11.9 @ 10500 rpm !!!
it used to take 7.5 seconds to pull from 20mph to 50mph now it does it in 5.9 seconds from 20 mph to 50 mph !!! very very strong smooth power. Feels great.
way to go dan !
great job
looks like we have a killer gpx engine on our hands now
Nice, what carb were you using?
Vince, I think I need to go full crazy mad scientist on one of dem... : )
soo what class r u planning on running this thing in if it a 145cc :banghead:
cr kid i'm shipping it monday to the BOSS. dyno sheets and all......someone is gonna be a lucky guy. it should run side by side to your average 117 se.....maybe a little more fun than that because of the insane low end it has......the 22 mm std. carb and a big gun pipe worked fine everywhere in the rpm band.....from low low end i mean diesel bottom to the highest revs peak @ 11000 it is clean as a whistle on the tune up.
I'm drooooooling!! I'll be sending you more cranks and engine's to get built real soon! :banghead::banghead:
Have you tested it with any other carbs yet, 24mm, 26mm? Or do you think the stock 22mm is ok?
Thanks Dan!
the 22mm that comes on this thing blows my mind how good it is.i'm sure there is more there with the 26mm but for now this thing is near perfect. Run it!! played with the fuel screw a little and raised the needle one clip......it might like a little more main jet also but i didn't have one, but hey for a lower end 22 mm it's impressive.
u can probably run an open 12 class, slap some bigger wheels on and battle the klx's
WOW!!! This is definately going to be a big seller! Just let us dealers know when these will be available for sale to the public.
I have got to git me one of deez!!
Great job to everyone involved! The dedication to the product is the main reason these are doing so well. Keep it up! :banghead:
were not done yet !!
What Is The Standard Main And Pilot For A Gpx Pitster Motor?thanks
Can you get a big bore yet online and where can you get a head for the GPX motor?
The 145cc is going to retail for about $950 (for the work to be done to your engine) Pulls like a freight train! Anyone with a Pitster Pro engine (GPX) can get this kit done in about two weeks. Or you can buy an engine complete with ALL the work done for $1295. call for more details.
Thats a 145cc start in any gear four speed manuel with carb ready to race!
I promise I'll have dyno's ASAP.
We can get you a head if you need one.
man maybe i should have gotten a bad azz pit bike instead!!!....LOL
you know thats right!
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: http://tboltusa.com/store/lifan-125cc-enginebrsale-price-p-1811.html ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
