High speed stability
I have just completed some minor mods. Given that a lot of people are worried about highway stability I thoght I might offer up my findings.
The Acerbis motard fender helped considerably the front end doesn't seem to catch the cross winds nearly so bad. The blue is liveable.
The Clarke 3.9 full is wicked the extra 10 ish pounds really seems to help. I guess it balances my fat a$$ a little.
Biggest bang for the buck.... The cool little baja designs LED and fender really helped the stability :banghead: .
Seriously the fender made a difference and the extra fuel seems to help as well.
mine tank-slaps and weaves and speed wobbles whenever anyone else rides it over 90km/h, I ride without probs at any speed-couldn't be happier with that situation :banghead:!
I cut my stock front fender for that exact reason. Haven't tried in out yet, but I hope it gets the same results you did.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
