Denroll Posted October 20, 2005 Alright, who do we have? I'm assuming B-man is on top with a (current) 55.5whp. I'm sitting at about 47whp (not fine-tuned) with the Millenium 450. Freewheeler stroker crank coming soon. Share this post Link to post Share on other sites
Fred_Bear Posted October 20, 2005 good question. I would like to know. Share this post Link to post Share on other sites
mickeydee Posted October 20, 2005 mabey if we all had free use of a dyno we would know Share this post Link to post Share on other sites
xXDr_Z250Xx Posted October 20, 2005 not mine. i'm guessing 40-41 tops with my S, if that. Share this post Link to post Share on other sites
harjp1959 Posted October 20, 2005 mabey if we all had free use of a dyno we would know It would have to be the same dyno. Share this post Link to post Share on other sites
NateTheGreat Posted October 20, 2005 I can only hope mine can be among this list someday soon.... 450 stroker. Share this post Link to post Share on other sites
mickeydee Posted October 20, 2005 It would have to be the same dyno. i know why can't they be all the same i read this one thread where this drz was 450ed and the dyno said 31 hp or somthing like that.that would suck.🤣 Share this post Link to post Share on other sites
Wayward Son Posted October 20, 2005 i offer free dyno runs for all TT'ers. there might be a couple guys within a couple peak hp of me.nobody will have the power spread or even close to the 40 ft lbs of tq. Share this post Link to post Share on other sites
flip18436572 Posted October 20, 2005 Burned, thanks for the offer. When will you be bringing the dyno to my house? If I am ever in your area, and have actually gotten to spend some more money on performance, I might actually take you up on that. Share this post Link to post Share on other sites
freewheelers Posted October 20, 2005 i offer free dyno runs for all TT'ers. there might be a couple guys within a couple peak hp of me.nobody will have the power spread or even close to the 40 ft lbs of tq. Ed, The coolest part of your HP/Torque numbers is that It is nothing more than the right combination of BOLT ON PARTS. Not to mention that your still running on pump fuel. No big valve or head magic ... YET!! Based on your dyno experience ... What do you think I'm putting out ... 475cc @ 13.4 compression T4 exhaust Way past 3x3 opening in air box "E" cams (no lob center adjustment) 40mm Keihin CVK carb (40.5mm actual) Share this post Link to post Share on other sites
Wayward Son Posted October 20, 2005 51-52 hp and 37-38 ft lbs tq. pretty close to where i was previous to the crf carb/intake,fluidyne rads and big core muffler. i think dialing in the lobe centers with a set of hot cam would really shock you how much power is hiding. Share this post Link to post Share on other sites
2wheels-drz Posted October 20, 2005 i offer free dyno runs for all TT'ers. QUOTE] when ya flying it over????? Share this post Link to post Share on other sites
MIGHTYMOUS327 Posted October 20, 2005 51-52 hp and 37-38 ft lbs tq. pretty close to where i was previous to the crf carb/intake,fluidyne rads and big core muffler. i think dialing in the lobe centers with a set of hot cam would really shock you how much power is hiding. IT WOULDN'T SURPRISE ME. THE STAGE 2 HOTCAMS WILL NOT BE THE BEST FOR EVERY ENGINE COMBINATION OF DRZ. HOW COME YOU DON'T USE BIGGER CAMS IN YOUR MOTOR? Share this post Link to post Share on other sites
Wayward Son Posted October 20, 2005 the cams im looking for do not exist yet nor do the valve springs needed.working with RHC right now on that. he also setting up a 2mm oversize valve head along being fully modifed/flowed. im still using a stock head. Share this post Link to post Share on other sites
freewheelers Posted October 20, 2005 51-52 hp and 37-38 ft lbs tq. pretty close to where i was previous to the crf carb/intake,fluidyne rads and big core muffler. i think dialing in the lobe centers with a set of hot cam would really shock you how much power is hiding. My winter project this year is to tear the engine down and install my second generation crank mod .... AND .... Install stage two hot cams ... or maybe I can be a RHC cam tester and of course adjust the lode centers. I'm also considering spliting my head gasket for more compression, based on you running 91 octane pump fuel. I'm running a 12.5 compression piston bumped to 13.4 due to the extra stroke. By spliting the head gasket, will put me at the same compression that you are running (14.35). I really like the 40mm CVK keihin that I am running, however I'm considering modding the butterfly and venturi to get more air flow. Any suggestions or tips will be appreciated. Share this post Link to post Share on other sites
Symoto Posted October 20, 2005 Hey Burned Re jetted and filter change for the European winter season 435cc head flowed valves triple cut standard E compresion 50.2 RWHP 45.5 N-m Torque (that'll about 35.56 of them there ft bl thingies) Maybe the cams in this baby are what your looking for but if I told you what they were my tuner would kill me :-) What do you think the 475 crank would bring hey ? Mark Share this post Link to post Share on other sites
GarryOwen Posted October 20, 2005 Burned, are you going to be working the week between Christmas and New years? I'm driving out to the Denver/Colorado Springs area then and would love to stop by. Share this post Link to post Share on other sites
Wayward Son Posted October 20, 2005 Hey Burned Re jetted and filter change for the European winter season 435cc head flowed valves triple cut standard E compresion 50.2 RWHP 45.5 N-m Torque (that'll about 35.56 of them there ft bl thingies) Maybe the cams in this baby are what your looking for but if I told you what they were my tuner would kill me :-) What do you think the 475 crank would bring hey ? Mark your not even close. first,what kind of dyno. second,my bike makes 55hp and 40ft lbs of torque. your cams would do nothing for my motor. Share this post Link to post Share on other sites
Symoto Posted October 20, 2005 Freewheelers Would you mind giving me a few more details on the stroker crank, I've read all the old mails, I think, and would really like to give it a shot. Do I understand the pin is not welded but braised in place ? I don't want to send a new crank and rod can you service a use rod ? when can you do the work and what's the turnround time, where do I send the crank ? Can you give me a price including shipping back to Germany ? Sorry for all the questions Mark Share this post Link to post Share on other sites
Wayward Son Posted October 20, 2005 Burned, are you going to be working the week between Christmas and New years? I'm driving out to the Denver/Colorado Springs area then and would love to stop by. i should be here.nothing planned that i know of. Share this post Link to post Share on other sites
