Lookin for a magazine article
Someone told me that recently, a magazine did a DRZ exhaust shootout (cuz he's suddenly selling a ton of Yosh pipes). He didn't know the magazine title, just that that's what a couple customers told him. Anyone else read this? What mag?
I get all of the big 3 magazines and I havent seen a DRZ pipe shootout since 00 when the first DRZ came out.
I have an old old pipe shootout where I took all the numbers out of the magazine and plotted them all in excel. If you have excel you can view it.
I have posted it a couple other times. Some of the pipes on it are still around.... so it has some limited value.
Nice, thanks.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
