drz cv carb question
i was just wondering,when i let off the throttle (when wide open)i get a pop or crack what is that a sign of(too rich?)05drz400sm full yosh rs3,dj kit for s model,150mj,25pj,needle at #3pos with shim 3x3 mod.alt-1400ft,temp 6-15C.thanx again :banghead:
depends on how bad.a slight pop on decel is normal.
as i slow down by engine braking i do get the normal decel pop mabey i should rephrase what i wanted to get across.when i'm at wide WOT and let off only a bit so that i don't get the engine braking effect so my susp dosen't unload then load then load again real quick(don't want to get bent out of shape coming in to a corner fast) thats when i get the pop or crack,more like a crack.i hpe that explains it better.thanks again :banghead:
going to check right know.thanx
checked it,no leaks.the humidity is at 92%and about 7C.starting to get cold
well went out today and it didn't do it?the weather is clear about 12C and humidity is at 70%
