3x3 mod...what did you use to cut out the hole?
doing the 3x3 finally and was just curious what tool you guys used to cut out the whole.
thanks -
Drilled 4 holes in the top...Each hole in
the corner of the square I was going to
cut. Then I used an exacto knife to cut between
the holes. Careful with the knife when cutting
as you'll need to put quite a bit of pressure
while cutting. If you have a portable hand
jigsaw that would be easier but just make
sure you block off the opening to the carb
so as not to get any plastic pieces in it...
Haven't done it on the DRZ yet, but on the WR, I marked my cutting lines, drilled 1 hole and heated up a bolt with a torch, inserted the bolt in the hole and ran the hot bolt along the cutting lines. Does a nice job, and than you can clean it up with a file.
Not saying this is better, but giving you another option.
use a 1" hole saw for a drill to cut the 4 corners, then cut from hole to hole with a drywall saw on the outside edges. cheap hand saw (about 5 bucks)made for cutting holes in drywall for switch and recepticle boxes. I placed masking tape on the top of the box to outline everything first with a pen... then cleaned up the edges with a file... if you don't have or don't want to buy power/torchs that will do it easier.. make sure you remove the filter no matter what you do, or you will be buying a new one... and be careful where the clearance to the bottom is narrow not to cut it too....
A soldering iron - if you mark the hole and work along a straught edge, it's very neat and accurate. A sharp knife trims up the edges so it looks like it was moulded that way.
Ian
Drew shape on box, drilled 4 corners with 1/2" spade bit, hand-held hack saw blade to connect the corners, sand paper to smooth edges, shop-vac to clean debris out of airbox.
If you choose a drill/saw then remove the filter first and stuff a rag into the intake. The goo on the filter loves the plastic bits.
covered the intake... drilled 4 small holes....then used a bare hacksaw blade...hahah
