SCOTTYZF426FLA Posted October 20, 2005 Gents, Well last night I made it out to the track with the TTR and the YZ 80 front end. It worked great execept the front wheel was bottoming and rubbing the front fender. Partly because I have the tubes way up in the triple clamp. I would drop them but the brake line is not long enough. I why can't I use the YZ80 line but not the TTR master cylinder. Any suggestions on a work around with out buying all the racket on ebay? Share this post Link to post Share on other sites
ndawg22 Posted October 21, 2005 did you keep the yz wheel on it??? if you put a L wheel on it might be big enough to make it rub??? if you slaped the whole front end one wouldnt it be the same as if it was on the yz??? im confused Share this post Link to post Share on other sites
SCOTTYZF426FLA Posted October 21, 2005 It is the TTR L front wheel. If you go to www.ttr125L.com that guy has done it. Just hoping a few guys have some suggestions. Share this post Link to post Share on other sites
dirttrackin280h Posted October 21, 2005 I had the same problem with my bike. The wheel would always hit the fender when I jump. So I put in the heaviest springs I can find which were .33 and put those in, and it helped a bit. Then I got spacers put inside the forks which stiffened them up as well. But the best way around all of that is to just get the forks revalved because there way to soft for the weight of the ttr. But if you dont want to do any of that, then your pretty much going to have to live with it. And on the brake line, there is no way around it. You'll just have to find a YZ80 master cylinder on ebay and then the line will hook up for sure. But you dont want to raise the front end that much because it will be uneven with the rear. So I would definetely go with the springs first. I got mine from racetech. Start from there. Share this post Link to post Share on other sites
SCOTTYZF426FLA Posted October 21, 2005 Does it still rub if you put the forks all the way out? Share this post Link to post Share on other sites
Hawker Posted October 21, 2005 No matter where the forks are located in the triples, or what wheel you use, the tire is going to botom out until you put different heavier springs in the forks. The stock YZ80 fork springs will not handle the wieght of the TTR. You will have to get a different master cylinder also. Share this post Link to post Share on other sites
Fastkid591 Posted October 21, 2005 I'm still confused. Share this post Link to post Share on other sites
BIGDADDY450 Posted October 22, 2005 Get a set a heavy springs like said from other TT members and like I said in one of your other posts. Cannon Racecraft has .38 springs for them,thats what im running,but I think now im going to opt for a set of custom wound .44's because I still bottom out on some of the big jumps. If you dont want to get a yz master, you can have a custom line made but it will probably cost you more than what you could find the master cylinder for on ebay. Share this post Link to post Share on other sites
dirttrackin280h Posted October 22, 2005 Where are you getting those custom .44 springs from bigdaddy? Share this post Link to post Share on other sites
