kxfreak   Posted October 21, 2005 i was wondering if there is anyway on how to get some more low end power? 🤣 Share this post Link to post Share on other sites
mxman502 Â Â Posted October 21, 2005 Add a tooth to your rear sprocket..... Share this post Link to post Share on other sites
fat250 Â Â Posted October 21, 2005 heavier fly wheel weight Share this post Link to post Share on other sites
XR650L_Dave   Posted October 21, 2005 On a what? has it been modded for more power already, or is it bone stock? What type of riding/situation is calling for more low end? D Share this post Link to post Share on other sites
kxfreak   Posted October 21, 2005 well, ive already done the sprocket, but i meed more low end for when riding the track, cause i have an older kx80 and its powerband is in the mid rpms, so when riding the track in the really muddy situation when i cant go through a corner, it bogs Share this post Link to post Share on other sites
ghoti   Posted October 21, 2005 Fan the clutch when it bogs. Share this post Link to post Share on other sites
skoot22 Â Â Posted October 21, 2005 get a bigger bike Share this post Link to post Share on other sites
Mike_Lettrich   Posted October 21, 2005 Definitely fan the clutch. Two strokes need to be ridden a little differently than a four stroke. 80cc two stroke mx'ers make a lot of power for their size, but it's mostly top end. They require more clutch use. "Fanning the clutch" means that when it starts to bog, pull in the clutch just a little bit until it starts to slip. Stay on the gas to get the rpms up into the powerband. Then let the clutch out and stay on the gas, and the bog is gone. Share this post Link to post Share on other sites
Dust_Devil   Posted October 21, 2005 Try the pink powerbands......They have more snap! Share this post Link to post Share on other sites
skoot22 Â Â Posted October 21, 2005 well, ive already done the sprocket, but i meed more low end for when riding the track, cause i have an older kx80 and its powerband is in the mid rpms, so when riding the track in the really muddy situation when i cant go through a corner, it bogs down shift Share this post Link to post Share on other sites
fat250 Â Â Posted October 21, 2005 Try the pink powerbands......They have more snap! oh really!! damn...and i've been using grey ones!! thanks for the heads up man! see TT has everything:thumbsup: Share this post Link to post Share on other sites
kxfreak   Posted October 22, 2005 ok, i was looking at flywheel weights, and i saw a variety of weight, so if i bought one which amount of weight would i want to get, also, what will the weight do? Share this post Link to post Share on other sites
ThumperMx365 Â Â Posted October 22, 2005 Get a pipe Share this post Link to post Share on other sites
Motocross26 Â Â Posted October 22, 2005 ok, i was looking at flywheel weights, and i saw a variety of weight, so if i bought one which amount of weight would i want to get, also, what will the weight do? No need to mod, downshift or fan the clutch and you're good. Share this post Link to post Share on other sites
