SDG help!!!
Talk to Don at Thumper talk, He can hook you up with parts, But they will cost you some money. Other then that twist the throttle all the way around.
take it apart and re-build it. Taking away all the shitty/low quality parts and replacing them.
great first mod to any SDG.
here is where u can get aftermarket parts for SDG:
http://www.hondaminitrail.com/AFTERMARKET.htm
thats allot of work when you could just replace it with more power for much less labor, and not too much cost.
www.pitsterpro.com
ok you take a ramp and put a dumpster 30 feet away from it ,then jump the ramp and make the SDG land in the dumpster and then you leave it there!!
Tighten all of your bolts and take that POS SDG motor out and use it as a boat anchor. Drop an XR50 motor in and slap a big bore on it. You might want to replace the rear shock, its a POS to.
