what would happen if?
i have a tb 88 kit with 20mm carb on my crf 50. i have way to much accelration which is not needed for me becuase i ride on the street and sometimes in like forests and do small jumps etc. i was wondering what would b the best sprocket for top end but that would still have some acelleration mabye the same amount as stock? also would my tb kit have enough power to push a 16 17 or even 18 tooth front sprrocket?
thanks
The 88cc kit has more than enough oomph to turn a 16, 17, or 18 tooth sprocket, but your engine cases probably don't have the clearance for the bigger sprockets. Bump up to a 15 or 16 up front, and if you aren't happy with that, then go to a smaller rear sprocket like a 34 or 35 tooth (stock is 37).
ahh ic how much speed will my 50 prduce top end with a 16 tooth front sprocket and a 34 rear sprocket?
16 is the max for the front...
30 is the smallest for the rear
