Pitser Gpx Jetting
I Have A Knock Off Bike With What Appears To Be A Gpx Motor And Has A Mikuni 22mm Carb With A 95main And 15 Pilot On The Second From The Bottom Clip Just Curious If Thats The Same Jetting U Got Or Are You Running Something Different Thanks
The Jetting on the Pitster is very good, But you can check Tech Info on our forum for more info, Or call Vince, he can help you with this info. Some engines may look like ours but that doesnt mean the run like ours. There are many differances to our engine to make them hold up better and run better.
www.pitsterpro.com
I left the jetting alone on my GPX 125 but I did move the jet needle up all the way (which was only one position) it was running a bit lean. It helped.
