TLRick Posted October 22, 2005 I had a major oil leak at the front sprocket. I took it apart and found that my front sprocket was loose. Being the "Wannabe" mechanic that I am, I started to take it apart to see if there was a seal that I could take out, take to the dealer, buy and replace. I know, I know, I should have looked here first. Anyway, after taking off the "Retainer" with my impact screwdriver, I took out some large, round metal thing (I guess it's a spacer and began pulling at the rubber that surrounds the outside of the hole. It ripped in several places and now I am wondering if it is the seal or not. I really hope it is and that it can be removed and replaced, even if I have to take it to the dealer although I would rather do it myself. Is THAT the seal or did I screw things up down there? 🤣 Does anyone have a picture? Please help me!!! Share this post Link to post Share on other sites
TLRick Posted October 22, 2005 I did a search but found no pictures to see if I am screwing it up more. Thanks in advanced for the help. Share this post Link to post Share on other sites
TLRick Posted October 22, 2005 Oh yeah, some small round spring thing came out as well. I really need to get a service manual but in the mean time, can someone help me out please. Share this post Link to post Share on other sites
nondem Posted October 22, 2005 It's the seal - get a new one...and get the upgraded spacer for it so it doesn't happen again. Share this post Link to post Share on other sites
xti Posted October 22, 2005 Which bike do you have the S or the E? Share this post Link to post Share on other sites
TLRick Posted October 22, 2005 It's the seal - get a new one...and get the upgraded spacer for it so it doesn't happen again. I have the "S" model. Please tell me for sure that the rubber outer ring in the opening is part of the seal so I can stop worrying and making myself sick. If it is, is that the only part (Besides the upgraded spacer) that I need to replace? What is the round spring thing and where exactly does that go? Thanks for the quick replies. Share this post Link to post Share on other sites
xti Posted October 22, 2005 Look closely at this picture and parts diagram and you will find the answer you seek. http://www.ronayers.com/fiche/300_0312/crankshaft_model_k1_k2_k3_k4/crankshaft_model_k1_k2_k3_k4.cfm Share this post Link to post Share on other sites
nondem Posted October 22, 2005 I'm pretty sure your talking about the spring that goes around the seal and holds it against the countershaft. The new seal has a new one in it. Share this post Link to post Share on other sites
xti Posted October 22, 2005 I think this is what you are talking about. Look at #10 09282-14003 Description: OIL SEAL Source: SUZUKI Price: $3.86 Share this post Link to post Share on other sites
TLRick Posted October 22, 2005 I think this is what you are talking about. Look at #10 09282-14003 Description: OIL SEAL Source: SUZUKI Price: $3.86 I believe that is the part that I took out. That goes in before the sprocket goes on right? The fiche makes it look like it goes on after the nut. But what about the rubber part that is on the outside of the large opening that I tore up? Is that replacable? I don't see that on the fiche. I swear I am driving myself nuts worrying over it. Share this post Link to post Share on other sites
JoelH. Posted October 22, 2005 You didn't cause any perm. damage. You need a new seal. Do a search on "countershaft" or "countershaft sprocket"to understand why it was loose and how it can be prevented in the future. I havan't done it myself so post any questions on installing the new seal. Share this post Link to post Share on other sites
Spud786 Posted October 22, 2005 ARe you riding the bike in alot of mud, on the street the stock spacers hold up fine. I replaced one at 14,000 miles, it did not need it and the other one now has 22,000 + miles. Next counter sprocket replacement I'll do the whole seal and spacer set up. if you ride in alot of corrosive mud the spacer will rust and tear the seal up. i assume the round spring thing , is part of your seal Share this post Link to post Share on other sites
TLRick Posted October 22, 2005 You didn't cause any perm. damage. You need a new seal. Do a search on "countershaft" or "countershaft sprocket"to understand why it was loose and how it can be prevented in the future. I havan't done it myself so post any questions on installing the new seal. I did a search and found out about the lock tite...thanks. I have only been in the dirt a couple of times and mostly ride on the street. The part that I am mainly concerned with is the rubber part on the outer edge of the counter shaft opening. That is the part that I tore up. Is that part of the seal? The rubber part that is on the outer opening. Share this post Link to post Share on other sites
GT80 Posted October 22, 2005 This is the fiche you should be looking at. http://www.ronayers.com/fiche/300_0367/transmission/transmission.cfm?man=su&groupid=1660&parent=1610 #23 is your countershaft seal. DO NOT order the part xti referenced! That is the crankshaft seal!! The new seal will come with the spring you mentioned. Pull the old seal out with needlenose pliers if you have to or pry it out with a screwdriver, it's shot anyway, just be sure not to damage the crankcase in the process. Drive the new seal in with a piece of pipe with a similar diameter as the outer diameter of the seal or tap it in lightly with a hammer in a circular motion. Look at the spacer too (Item #34). If it has a groove worn in it go ahead and replace it also while you're in there. BTW, aren't you on TLP? Share this post Link to post Share on other sites
BikeRider Posted October 22, 2005 GT80 gave you good instructions. Another thing that works good driving in seals (besides a seal driving tool of course) is a socket of the correct size. Make sure the socket is hitting the beefy part of the seal, not the inner lip part, so that you are driving against the solid part of the seal. Then just tap the seal in with a hammer. Make sure to keep it straight as you drive it in. Take your time. If the seal cocks, stop, straighten things out and go again. Never force anything when your working on a motor. Once the seal is mostly in, you can stop using the socket and just tap the seal, so you can see when it is flush with the side of the case. Did I mention to take your time? Motor work can be fun if you let it. Share this post Link to post Share on other sites
TLRick Posted October 22, 2005 Thanks. Part Ordered. Share this post Link to post Share on other sites
Neil Claydon My Ride Posted October 22, 2005 Make sure you only push (tap) the seal in until it is flush, NO FURTHER. NEIL. 🤣 Share this post Link to post Share on other sites
xti Posted October 23, 2005 Sorry about the wrong part number. It was late and I was half asleep when I posted. Thanks for correcting my post GT80. Share this post Link to post Share on other sites
TLRick Posted October 24, 2005 Ordered the part...hopefully, it is the right one but the dealer seems to think it is after showing him a picture of my counter shaft. Thanks. Share this post Link to post Share on other sites
