Help!!!!
hey i have a complete takegawa 88cc race kit it came with everything. i got it proffessionally installed it ran fine for the 1st three days but then when i was going into hign rmps it boggs then goes to the powerband and if i ride it more and get the engine hotter it boggs or sputters more im 13. and the last thing is when its on the stand and i hold it wide open for at least 10 second it sputters. can anyone help me???i also have a cr 80 but that thing flies and is ok.
now that its getting colder you probably are experiencing a lean condition and need to move the clip on the needle down a notch or two. Try that first and if it doesnt work get a larger main jet. Another possibility is your valve clearance is out of wack. you can do a search to see what it is supposed to be set at but I would guess somewhere in the range of .003.
