Dynoed my S today..... about to put my 450 stroker in.
Today I took my bike to Folsom Cycle and had them run it on the dyno.
I am going to get the run files emailed to me and I will show some graphs after plotting it in excel.
Here is my setup:
- Yosh TRS Ti system.
- E base gasket
- CR8EK plug
- OEM E model FCR39
- JD Blue needle clip 4
- 162 Main
- 38 Pilot
- Flow Commander FC2000 intake stack + my airboot mod
- Stock S cams
- E model CDI
- 91 Octane CA pump fuel
- Fairly dirty air filter.🤣:banghead:
And what kind of peak numbers did it pull???
- Dynojet 250 Dyno
44.21 HP
29.69 Ft-Lbs torque
Whats more impressive is it pulls 40+ HP from about 7K all the way to the limiter. Numbers look pretty good for stock S model cams and 400cc. And I'm tellin you the flow commander tacks on some power. :banghead:
After I drop the 450 in I will go give it another whirl.
Nate, those are great numbers........how much did the Flow Commander run you again???? (too lazy to search, the wife just brought me a Margarita!) :banghead::banghead:🤣
Ya the dyno had a sniffer on it. I didn't grab the printout though. The mechanic runnin the dyno said 13.1
I am just waiting for the data files to be emailed to me then I will have everything.
My Flow Commander post :
https://thumpertalk.com/forum/showthread.php?t=259171
Page 3 of that post has my before and after data showing it made an improvement.
Forgot to answer your question... $150
Here is a graph I scanned in. Some of the torque graphs got spikes in them from bogus runs wheel hop or something. The blue one is a good torque number.
The 3 runs you see here 1 is 3rd or 4th gear the others are 5th gear. Its plotted vs. speed. :busted: But it revs out at 10K (E CDI) so you can see RPM is about 100 x the speed. When I get the data sent to me I will plot it as something that makes more sense in excel.
Wow that's some good numbers. Are you going to hotcams as well ? I only have a stg 1 intake cam in my S and I could feel a slight kick afterwards, should work great in your bike !
My 450 Motor I am working on slapping it together right now :
- Hotcams in and out Stg 2
- KW Valves
- KW valve springs with Ti retainers
- Hinson clutch basket
- Full moose clutch components
- New bearings, gaskets and seals all around
- New rod
- New rings
- Replated / diamond honed cylinder
Its a Yoshimura Stroker motor out of a Team Suzuki bike. So it has +5mm stroke and a 92mm JE 2 ring piston.
So yes the hotcams are going to work great in the bike.🤣
Edit :
Oh Ya I forgot to mention I have :
- A Lightened Rotor
- An original working Yosh 11K CDI
Since the motor is a kicker motor the left hand crank half is shorter therefore lighter. Add the lightened flywheel to that and rev out to 11k..... Its gonna be a beast and rev up fast. I cant wait. :banghead::banghead:
- KW Valves
- New rod
- New rings
Edit :
- A Lightened Rotor
since it's for a kicker. are you rewinding the stator to get better lighting outta it?
Impressive mods. I'm jealous. but it's not like I need more power, except on the street. but I dont think even burned's bike would have enough fo me on the street. I'm too used to flogging 100+ HP bikes through the twisties.
The OEM kicker stator puts out 150W peak vs. 200W for the E/S Which is more than enough to handle my street legal stuff anyways. So its all golden.
Its primarily supermoto duty so more HP is always a good thing and can be put to use.
Save your jealousy for the after dyno..... Your gonna need a high supply of it. :banghead: :banghead:
i wouldnt be so sure until you rode one.my bike will flat kill most sport bikes till 100mph.
I can believe it. With my mods right now I can pull 0-60 times in the 4.3s with stock S wheels and stock S gearing.
Add 11HP and a ton of torque and it should be down at 3 seconds like the fast street bikes....
I'll be doin some 0-60 with the 450 soon. :banghead:
Still workin on putting the 450 together. I should have it mostly done this week / weekend but I have to order a couple parts to finish it. I will keep you guys posted. :banghead:
For those in the know:
Take Nate's setup and throw-in a Hotcam's Intake: how would that effect the given numbers?
yeaeh, after I typed that I realized I didnt take into accout power to weight ratio. the extra 150 ish lbs on a sport bike really eats up those extra ponies. not to mention the inline 4s dont start making power till about 2/3 of the way into the rev range.
classic case of open mouth insert foot. :banghead:
Those numbers with S cams? :banghead: It's also nice to see that you could dial in the FlowCommander correctly, just by the seat of you pants.
