njdent Posted October 22, 2005 saw an article in MXA to make an X into an R but you basically need to strip an R of parts. Can you just use cases and e start setup on an R Share this post Link to post Share on other sites
mharry860 Posted October 22, 2005 Not unless you also use all the x internals. The gears are wider, so the case is wider, so then it probably won't go in the frame. Share this post Link to post Share on other sites
KRAYNIAL My Rides (7) Posted October 23, 2005 There are only a few parts that are interchangeable from the R to The X. The frames are very different. Share this post Link to post Share on other sites
