johhny Posted October 23, 2005 i no this is a 4 stroke forum but i need help bad there is oil coming out of my silencer on my cr 80 please help! Share this post Link to post Share on other sites
cr250ryan Posted October 23, 2005 Well thats called spooge, friend. All 2 strokes do it to some degree. Either you're not riding quite hard enough, or you are running a little rich. I figured I'd save you the flaming by answersing the question instead of telling you to get a thumper, but hey I like them smokers, too. Pull the plug and see if it is dark brown or black, if so you'll need to jet it properly. A light chocolate/tan is the color you want after a hard run and plug chop. The reason 2t's do this is simple, there is no oil sump for lubrication of the bottem end and rings. Instead the oil is either premixed with the fuel (most likely) or injected after the carb and before the intake. Not all the oil (or fuel for that matter) in the combustion chamber always burns, and some ends up going out into the atmosphere (eek!) and getting all over your silencer. Just wipe it off and keep on smokin! Share this post Link to post Share on other sites
johhny Posted October 23, 2005 ok thanks i to it to the track and it ran just fine. Share this post Link to post Share on other sites
Racer Posted October 23, 2005 No worrys! As cr250ryan said, that's normal. Share this post Link to post Share on other sites
