02 YZ250F Lightweight Rider Stiff Suspension
I have a 02 YZ250F My son is currently racing it in the 125D class, My problem is He only weighs 125 pounds. The rear suspension seems to be fine, We set the sag at 100mm and backed the clickers out 2 clicks from wide open. However the front forks are a different story,I opened both top & bottom clickers on front forks all the way to the soft side, it is still too stiff, I also checked for trapped air in the fork tubes, there was none. Does anyone know if lighter springs are available, or would changing to a lighter weight oil help?
He really needs softer springs on both ends. They are available so just check with your local tuner or call Cannon Racecraft.
doc
