whats wrong with my xr70
ok so one day i was ridin my 2001 xr70 when i shifted into netural i couldnt shoft back into 1st.. it takes all my strenght with both arms to put it into 1st now but once i get it into 1st it shifts fine... i think the shaft might b bent... any suggestions
Take off the clutch cover and check the shift mechanism and shift detent. All located in the upper rear corner. Honda has had some problems in this area over the years.
Those parts are easily replaced if you find something broken. You'll need a special socket to remove the clutch, pretty cheap from Motion Pro.
It's easiest to do this, especially reinstalling the clutch, with the unit on its side.
