better milage for z50r
i ride my 84 z50r on the pavement almost 99% of the time. so how can i increase gas milage if i ride in third gear most of the time and at high rpms? i leaned the carberator up quite a bit but not too much. is there anything else easy to do?? :banghead: thanks :banghead:🤣
On the rear sprocket go two or three teeth smaller or on the front I would go one tooth larger. This will give you more top end. So you can go the same speeds but at lower rpm's.
