Hard to select second gear!
Need some advice as to why my 02 450 will not select 2nd easily.
Feels like I have to pull up as hard as I can to attain gear.Rest of the gears are fine.Problem just started, was fine untill last ride. Any advice would be great.
Same here, it's the only shift I miss, but it's very sporadic. Using the clutch seems to eliminate it, but I'm usually to occupied to bother.
I would check it out a bit closer. I lost all my gears. Obviously mine was a little more serious but i had to have a complete engine rebuild. I lost all my gear cogs.
lever is fine. It seems to just lose 2nd gear. It takes a few shots at trying to hook 2nd then it'll engage. It sucks.
