Opinions on a combo of parts
I just received a 2004 engine to go with the 2 2002 engines we have been using. Noticed that the ignition module is different, so, doing a search here seems to say the 2004 ignition is a different curve, and is probably better, and there are just a couple of things to be able to use the 2002 stator with the later ignition...
But, I wanted some thoughts on this - we have been using 2004 pistons in the 2002 motors, and one has a Hot Cam Stage 1.
1. Would the newer ignition help the 2004 pistons perform better?
2. Would the newer ignition help with the Hot Cam as well?
Is this a better combo? 2004 piston, HotCam, 2004 ignition
Than what we have been doing with the 2002 ignition?
I would add that we have so far found running a more stock setup has been better, faster, and easier to keep running than those that have been doing heavy mods around us. So, I am not looking for the "most" built combo. Looking for mild, but, beneficial changes that move our performance in the right direction.
Thanks
It will be very difficult to positively say without doing some testing. I believe Honda claimed a new map every year between 02 and 04. I don't think it is public knowledge as to what exactly these maps consist of.
If you have an understanding of electronics and could actually understand what you are seeing, it wouldn't be impossible to extract the maps from each module for comparison.
I think a more practical method to get you to what you want without all the potential wheel in mud spinning would be to run back to back dyno tests on your custom setup.
Maybe someone here has already done testing on a similar setup.
Sorry I just realized I didn't really say anything useful.
Just checking to see if anyone has some thoughts on this. Seems when I post thoughtful questions there isn't a lot of help, but, a dozen answers on how much tranny oil to put in.
Melted down ass blubber of a teenage walrus clearly is the best choice for a transmission oil. Got a problem with that?
Heh, sorry. Glad someone finally gave a useful answer here.
burned,
would you say that the trend holds true with all of the years? ie the newer the module the better it works regardles of engine year and combo.
Burned, thanks for the info. Is there any info on the cam profiles of the different year cams? Are the O4 and O5 cams more aggresive and better performance, on the order of the mild aftermarket cams? In one sanction the engines rules are "Stock" but there isn't anything about mixing stock parts. So, if I can get a better cam using a stock part from another year, that would be great.
Thanks for the compliment. I posted new pics in the garage from Nov'05 at Road Atlanta. We changed to white bodywork. If you want to know more about Superkarts let me know by PM, I can point you to websites and more pictures. USSC is United States Superkart Championships. This is a pro organization, this isn't strapping something found in the backyard onto four wheels and seeing what happens. This is real, organized, sanctioned, racing on full size road courses.
Now back to the topic:
Best stock cam?
What is the compression ratio of the 05 and 06 pistons? I understand that 04 is 12:1 versus the 02/03 11.5:1
Thanks
for what your doing with the motors, Id say the best cam would probably be the 02. Its a more high RPM cam. Although Id say the best cam for what you're doing would be an RHC187.
Your best combo would be 04 piston, 05/06 ignition (you'll need an 04-06 harness for it) and the 05 air boot, (if your running an airboot at all...)and the 02 cam if you have to use OEM parts.
Ive started collecting all this stuff for my 03.
FYI:
The 04-06 crank shafts are quite a bit lighter than the 02-03. Not sure how that would affect a Kart. But it seems like auto racing is compeletly different that motorcycle racing and the least amount of reciprocating mass is typically what you look for.
Have you had any issues with the transmissions? There is another guy on TT that uses the CRF450 in thier cart and they had an inordinate number of trans problems. I figured it was the traction.
Hi everyone - thanks for more good information. I will ask a couple of more questions and answer a few as well.
I am assuming the "air boot" is on the air intake side of the carb, not between the engine and the carb, is that correct? If so, then we are not using anything there, we have an air filter adapter attached to the carb and a universal Unifilter attached to that. The adapter provides a short "air horn" sorta thing but mainly provides a transistion from the carb intake diameter to the air filter diameter of 2.5"
What is considered "High RPM?" We shift a 10K (or pretty close, 10.2 maybe max) and in 5th are so far geared to top out at about 9.2-9.5K We are still working on better gearing. Depending on the track and the length of the straights, we might be holding rpm for 30 seconds. See discussion of "2 strokes" below
The best stock cam for power is the 05/06 - what kind of power? Low end? Or across the entire band? See discussions of 2 strokes below.
Thanks for the tip on the cranks. I will discuss with my engine builder. See the rod discussion below.
Now some answers
1/4 mile time? I don't know, but, I can give you some laptimes -
Portland International - 1:12 - average speed of 98+ MPH
Thunderhill Raceway - 1:55 - avg 93+ MPH (we have some work to do there)
Road Atlanta - 1:33.6 - avg 97+
Top speeds of about 120 or so. For 2006 we are working on the aero package a bit and should be able to improve that a few MPH.
Reliability? We have only had 2 engine related problems so far:
1. Broke a rod at our last race of the season in the 2nd engine I bought used from a fellow TT person off an ad here. I am not putting that on anyone. We didn't know how much time was on the engine, and both engines were planning to get heavy duty rods this winter anyway, just had to get a 3rd engine though, and that is the newer '04 that started this whole discussion.
2. Some jumping out of gear on our original engine. Will go through the tranny this winter.
We had two other major catastrophies but they were clearly induced by the first shop that was working on the engines. Details left out to be polite.
Against the 2 strokes - well at the end of our first season (2005) we seem to have measured up well. There were 2 competitors in the western series that seemed to have a little more than us, and if they had it all going right and hit the tune, would have us by a second or so, but the rest of the field we would have covered. Our on track reliability is much higher. These are fully wide open single cylinder 2 strokes as well. Only spec is bore and stroke for them. When we went to Road Atlanta for the Nationals, again, we had a couple of the 2 strokes to chase, the top guys, but otherwise we had the field covered, including several built 4 strokes as the USSC rules for 4 strokes is "under 500 cc" it is IKF that limits us to "stock/oem" The qualifying results at Road Atlanta went something like this:
1st - 1:31 and change - CR250
2nd - 1:32 and change - Gas Gas 250 (Euro engine)
3rd - 1:33 and change - us with the CRF450R, '04 piston and hot cam stage 1 '02 ignition
4th - 1:38 and change and the rest of the field following that.
Also, several of the "built" 4 strokes (yamahas and hondas) had failures of various kinds, during the weekend.
So - we are looking for just a few horsepower without compromising reliability to give us just that last little bit. We seem to have the kart sorted, and working well, our tires are looking great and lasting well. Some things we are working on is an improved cooling system, that is more aerodynamic, right now we are running too cool. So, by rearranging radiators, and having more control over the air flow, we can get the temp up.
Also, we will be able to better route the exhaust, which may result in a little improvement.
So, anymore thoughts are appreciated. I am appreciate the support.
Sorry for the long post.
Happy New Year
Oh, and is the counterbalance shaft different between the older and newer crankshafts? I would think so if there is a weight difference
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
