MSR Raptor Perch Install Help
I got a MSR raptor clutch perch for christmas :applause:, but in the process of installing it, I noticed there is a peice that can be adjusted, just under the plastic boot. It has three notches, triangle in shape. Where should it line up? In the middle slot for the middle pull position? Its hard to describe, but I hope someone will know what I am talking about. Dont want to do it wrong and screw something up.
you got an easy clutch perch.you can adjust the amount of effort to pull it in.when you change this it also changes the engagement point.I answered this same question about a month ago.try to use a search function if all else fails.on a 125 you shouldn't need the easy pull just a raptor.I would exchange it.
