1997 xr 400 throttle sticking! HELP
i have a throttle problem it sticks :applause: does anyone have any info or tips to help me sole this prob thanks
If you have barkbusters check the grip end. If you have torn the carb down before this happened make sure you didn't install the slide backwards (I was guilty of this one once :applause: ). Check the throttle cables for pinching...
If the cables have never been replaced this would be a good time to do so. While you have them off operate the throttle shaft by hand to make sure you dont have other problems with the carburetor itself.
you can get aftermarket or stock.
the aftermarket ones will probably be a little bit more than the stock ones.
Step one is taking off the throttle tube.
There might be dirt or mud making it stick.
Clean it all up and lube it. Leave it dry between the tube and handlebars.
New cables do make an amazing difference.
Next is checking the carb to make sure the slide is not sticking.
good advice :applause::bonk:
check and make sure the throttle tube isn't broken. Also, if you've recently got new grips, depending on the severity of the sticking, it could just be that the grips are still getting broken in.
really? I was always told to put a layer of grease in there to keep things slippery. Is this wrong?
thanks for the help boys i took the throttle off cleaned it up and its fine now thanks again
